Page 5 of 5
Re: Chrysler marine replacement distributors
Posted: Sun Jul 17, 2016 12:09 pm
by MyWay
Ok what is the part number for the 318's is it the red cap or black cap, what's the difference?
Posted: Tue Jul 19, 2016 10:17 am
by nicklaw1
What was your outcome? I have been having some issues with my ignition and i am assuming its the advance. Im not very technical, but i dont want to get into a huge mess with modifications etc that i dont understand. Just looking for any more insight on ordering these replacements.
Posted: Tue Jul 19, 2016 11:41 am
by jmonday
What year and rotation is your motor?
Posted: Tue Jul 19, 2016 12:51 pm
by ericinga
I bought Pertronix distributors last month. The two part numbers are D241801 (Red Cap) and D241800 (Black Cap). I believe the part number difference is the cap color.
Posted: Tue Jul 19, 2016 2:06 pm
by jmonday
That is correct the 00 and 01 is color of cap only. Again If I was ordering a new one I would talk with them when placing the order and tell them the dimensions on the spacer to make sure the new stock is in. Here is what the last one I ordered measured. over all length 4 inch shoulder .600 counter bore.387 chore dia 2 inch
through hole 1.250
Posted: Tue Jul 19, 2016 7:56 pm
by MyWay
85 and it is the ccw starboard . Motor get up to 2500 rpm and starts cutting out or back firing .
Posted: Wed Jul 20, 2016 11:21 am
by jmonday
I am just down river from you. I could help you figure it out if you need it. Across from the casino boat Rising Star you can find us a boat named the Fancy Free or Blue Monday's docked on the main river.
Posted: Thu Jul 21, 2016 6:40 am
..."Motor get up to 2500 rpm and starts cutting out or back firing."
Mine did that and it was crossed plug wires. Try this: Using insulated gloves and pliers, pull one plug wire out of the cap at a time and note if the engine slows down. If it does, put it back in and go to the next one. When there's no change in rpm, leave that one out and look for the second one. Then switch the two.
PS: With the wires stuffed between the valve covers and the manifolds, it's very easy to mix a few wires up.
