Bottom touch up opinions
Posted: Mon May 13, 2019 7:28 am
by cantolina
My 32 is sitting on land right now, newly purchased. I was originally going to just hit the hull with SS wire brush, sand/prime the spots that are bare (not a lot of spots, but some). And rollover 3 or 4 coats with the paint the PO used. It surely needs to be stripped/done clean soon, but not until I get her home. I have found that Trilux is no longer available in the red on it now. It does come in black, which might be the color I use when I redo the entire hull.
I'm looking for opinions on what will protect the hull for the next season, before I launch and drive home.
Thoughts? What would you do, assuming a complete redo is out of the question right now. (several reasons)
Re: Bottom touch up opinions
Posted: Mon May 13, 2019 3:58 pm
A couple of items
-I always put a different color on top so it acts as a signal coat. When the top coat wears, you can see the spot immediately.
-I just wanted to be sure that once you sand a spot you get on at least the primer spot within a few hours, not the next day - aluminum skins over (oxidizes) quite rapidly.
Posted: Mon May 13, 2019 5:31 pm
by cantolina
jralbert wrote:A couple of items
Thanks, Joel. I did think the new color over the top was a good idea for the same reason, but I'll be stripping and repainting fresh next year, so that's not really a thing right now.
I am aware of aluminum oxidation rates. Thanks for the reminder, tho.
Posted: Tue May 14, 2019 6:44 am
by jennis9
I’d use a green scuff pad instead of the wire brush.
Are you on the Facebook group as well?
