Bow Rail Restoration
Re: Bow Rail Restoration
Postby bill » Thu Jul 06, 2017 6:21 am
Thanks Carl for the great write up and pictures. I guess time and mother nature will tell if solid spacer or single washer are the best.
USCG Master Lic. Retired
ddependo
Postby ddependo » Thu Jul 06, 2017 3:28 pm
Let me make a comment. Carl is just a few slips away from me on the same dock & I've watched and admired his progress in making his M better than new from the factory. He does all the work himself even tho he works all over the world and is gone 3 months at a time sometimes. Jeff and Carl are real smart guys( I forgive Jeff for not wanting a fly bridge). Both engineers one working one retired. Jeff & I take the same fugal "cheap" approach even tho Jeff has all his money buried in his back yard. I have none. Carl shops for the best price but in my option goes first class because he is going live on the boat. I consider both be be friends and have contributed a great deal to our love of Marinette boats. Carl is headed for the Bahamas, Wish I could do that.
Postby honestcharlie56 » Thu Jul 06, 2017 5:31 pm
Carls progress makes me not want to go to my boat....thanks Carl. All kidding aside, we all love to see the progress.
Postby Fastjeff » Thu Jul 06, 2017 5:38 pm
..."Jeff has all his money buried in his back yard. "
Shhhh!
bpboater
Postby bpboater » Wed Jul 19, 2017 2:20 pm
I like how both Jeff and Carl handled the bow rail corrosion issue. I repaired my rail bases in 2009. Before doing it, I called the engineers at Broward Yachts which are all aluminum and normally in salt water. They acknowledged the tough nature of the problem. Their solution in 2009 was to weld aluminum cups to the deck of the boat, then glue a perfect fit delrin cup in the aluminum cup, then glue the stainless rail into the delrin cup. They believe they achieved a waterproof mount with no dissimilar metals touching.
Paul
1988 41 Marinette
Westerbeke 8.5 kw BTG
Lake Cumberland, KY
carl
Postby carl » Sun Jul 15, 2018 9:20 pm
Today I installed my flag staff socket in the gunwale center transom with a 1/4' Starboard insulator. I also started drilling and installing the aluminum Rivnuts for the Aft deck rail stations. More details to come...
Twin Crusader 350's
Chickamauga Lake, Tennessee
carl
Postby carl » Mon Aug 20, 2018 7:02 pm
Another update on my progress separating and isolating from one another the dissimilar metals (aluminum and stainless steel) aboard my Marinette. Here are some more pictures of the starboard insulators I have installed to date...
Twin Crusader 350's
carl
Postby carl » Mon Aug 20, 2018 7:04 pm
Four more pictures...
Twin Crusader 350's
Postby Fastjeff » Thu Aug 23, 2018 6:38 am
Beautiful work, but (there's always a "but") I would have 'relieved' the bottom of those plastic washer deals to let water flow beneath them. The original rubber gaskets tended to create crevasse corrosion.
carl
Postby carl » Thu Aug 23, 2018 7:56 am
All of my Starboard material spacers are gapped between them and the aluminum skin of the boat. If you look at all of the pictures closely you will see that the aluminum rivnuts crimped into the holes have a flange, this flange is similar to a flat washer, the Starboard material spacers rest atop these rivnut flanges leaving a gap of approximately 1/32" (I'll mic the flange to get an accurate measurement) between the aluminum and the spacer allowing water and air to pass underneath.
Twin Crusader 350's
