Borg Warner 1.91 : 1 - Neutral Safety Switch??
Posted: Mon May 01, 2017 6:57 pm
by Leviathon
Am I missing something or is this tranny missing a NSS? I cannot locate one. There is what seems to be some type of pressure switch on the top of the tranny - not sure the purpose. I will see if I can get a pic, unless someone can unravel the mystery without it. My old 1:1's had the NSS on the side of the tranny.
Re: Borg Warner 1.91 : 1 - Neutral Safety Switch??
Posted: Mon May 01, 2017 8:27 pm
by javalin390
Are they in the shifter levers? I've never really looked.
Posted: Mon May 01, 2017 9:33 pm
by EWRice
If your trans has the switch on it, it would be directly opposite the shift lever, on the right side of the trans. It will be threaded into a small cast cover with 3 bolts holding it to the trans. 2 screw terminals for the wiring.
My boat never had safety switches. Just a small 3 bolt cover over the shift valve. I have seen some shifters with safety switches built in, but not often.
If you need to add one, I should have all the parts to do so.
Posted: Tue May 02, 2017 6:10 am
by Leviathon
Thanks - I have a couple trannys laying around with them, hopefully and easy swap of the switch.
Posted: Wed May 03, 2017 6:31 am
Easy swap. It's on the starboard side of the tranny.
Posted: Wed May 03, 2017 7:55 pm
by Leviathon
Always sounds easy -starter was right in the way so had to do some external modification to the exterior of the switch with a grinder. - Only I will know!
