Spark Plug Wires
Spark Plug Wires
Postby honestcharlie56 » Sat Sep 09, 2017 9:49 pm
I usually see people complaining about the stock style spark plug wires. I bought a universal set with 90* plug ends and they fit great. Of course, you still have to cut the wires to fit and terminate the distributor end. See below!!
https://www.amazon.com/gp/product/B000A ... UTF8&psc=1
Re: Spark Plug Wires
Postby Fastjeff » Sun Sep 10, 2017 6:58 am
Looks good. Did you go under the manifolds or stuff the wires between the manifolds and valve covers?
Postby honestcharlie56 » Sun Sep 10, 2017 7:51 am
Not only were the original wires corroded from the, as you have seen, sinking.....but I couldn't stand the fact that they were stuffed in there and hardly serviceable. They made breaking in an engine quite difficult, as I really like to plug the plugs often to check whats going on inside the cylinders. So I got these to route them outside of the manifolds. Just like you have recommended on both this site and the Marine Engine Forum. If we can get you on "The Hull Truth", Fast Jeff will be everywhere.
I'll take some pictures this morning when I go to the boat.
Postby bcassedy » Sun Sep 10, 2017 9:22 am
Not being a true "gear head" but more of a "shade tree mechanic" (tuff to do on a boat! :-) )...
Is there a downside to routing plug wires on the outside of the manifolds (length more than heat)?
'88 32' Sedan Bridge
Twin 318cu in Chrysler
1.5:1 Velvet drive trannies
Fresh water only
Postby honestcharlie56 » Sun Sep 10, 2017 8:56 pm
I don't think so, but couldn't objectively prove it one way or the other. Mine are working fine though. Took a two hour cruise and checked the plugs, they looked great.
Postby Fastjeff » Mon Sep 11, 2017 6:02 am
The strongest DIS-advantage to the factory wiring mess is it's very easy to confuse the wires.
The marina guys did that to me (during an insurance settlement deal) and it drove me nuts trying to cure a backfire under throttle. Changed all kind sort things before finding they had two plug wires reversed. (Dopey me; I should have done the 'pull one wire at a time from the distributor' test.)
All in all, much easy to work on the motor with the wire outside the manifolds.
Postby honestcharlie56 » Mon Sep 11, 2017 8:01 am
Yes sir! I can easily pull one wire off, pull the plug, and then reinstall in no time flat. Used to have to sit there and fight the plug wires
jmonday
Postby jmonday » Mon Sep 11, 2017 9:30 am
Does anyone know of a set of wires pre-built that work outside the manifolds?? I have seen a couple of people what say big block chevy wire set do but really would like the part number if anyone has the info.(Mine run outside and I like it much better than the factory setup.)
Jeff Monday (Blue Mondays)
Lower River rd
Rabbit Hash KY
Postby honestcharlie56 » Sat Nov 11, 2017 9:15 pm
The set I posted originally are extremely easy to cut and fit.
Trowerpower
Postby Trowerpower » Mon Mar 26, 2018 6:24 am
Performance Distributors (DUI) out of Memphis, Tn. Has excellent spark plug wires. Ordered mine four inches longer than an automotive 318 with straight spark plug boots. They fit perfect routing through the exhaust manifold openings. Check out their distributors when you go to their website. They were $99 a set a few years ago.
Trower Power
Blue Sky
750 Edlebrocks
fresh water cooled
1.5 to 1 velva-drives
Onan 6.5kw gen set
