Exhaust manifold surface?
GregM
Postby GregM » Mon May 21, 2018 6:41 pm
Should I prep and paint exhaust manifold surface with prep and paint with 500 degree paint or go bare metal with the gasket?
GregM
Re: Exhaust manifold surface?
Postby GregM » Mon May 21, 2018 6:43 pm
Oh and what about forma gasket? should that be used with the exhaust gaskets?
Leviathon
Postby Leviathon » Mon May 21, 2018 6:46 pm
I would paint, but high degree paint not necessary. Paint on the bottom where it bolts to head will burn off no matter what you use - the rest does not get that hot. I always use a sealant with the gaskets to fill in all the nooks and crannies - others may not. Just re-read your email. If your talking about painting the mating surface, I would not. Just bare metal.
Steve and Mary Levi
1973 32' Marinette Fisherman
Twin Chrysler 360's
El Ohssa
St. Joseph, Michigan
