trans noise
ddependo
trans noise
Post by ddependo »
OK Marinette brothers, Have a new one for me.
Just completed fixing ring gear on port engine. Got everything back together and starts fine but makes a clunking noise in neural at all rpm range. Put in gear , forward or reverse and noise goes away. Sound like it is coming from area of damper. Damper looked ok when apart . Any suggestions. I don't think I have enough blood left to take it all apart again. Rough job for a old man!
Re: trans noise
Bad damper plate (sprngs).
Re: trans noise
Post by EWRice »
If it didn't rattle before, but rattles now, I might suspect the bolts mounting it to the flywheel didn't get tightened. At least those can be checked through the timing hole.
Re: trans noise
Post by javalin390 »
Not sure if Chryslers suffer the same issue, but the flywheel on GM engines sometimes crack around the bolt holes at the crankshaft, which causes a clunking noise in neutral.
