Exhaust manifold tubes
liquidplummer
Postby liquidplummer » Sun Jul 28, 2019 4:08 pm
I am replacing a leaking manifold/riser/swivel elbow on my 360 Chrysler. It has the log style manifolds with exhaust to the rear. The original manifold was installed with the water tube and had the water entering the front of the manifold at the water tube.
My new manifold (Barr) instructions says that water should enter from the bottom front to use the water tube and no tube is used when enter through the front top. The present setup has worked for 37 years. How have others installed new manifolds
Silver Queen St Louis Mo
Re: Exhaust manifold tubes
Postby Fastjeff » Sun Jul 28, 2019 8:06 pm
I left those suckers out and never had a problem--and the water came in the front! (PO set it up like that.)
Harryb
Postby Harryb » Mon Jul 29, 2019 5:03 pm
My two new rebuilds are set up per the barr instructions, leaving the tubes out and both run nice and cool.
Postby Fastjeff » Tue Jul 30, 2019 7:03 am
Thank you!
I believe the original design was a case of over-engineering.
