San Juan Strainer Upgrade
Posted: Fri Sep 11, 2020 10:57 am
Came across this strainer on a 2011 Cruisers Cantius. Used for air conditioner pump. The lid is very solid and seals very easily after cleaning. There is a rubber gasket around the edge of the bowl but the bottom of the lid identical to the top, solid brass except for the inspection ports. The center gasket is under the hex bolt on the outside.
Might be a worth while upgrade?
https://drive.google.com/file/d/1f_bcL2 ... sp=sharing
https://drive.google.com/file/d/1eR3opB ... sp=sharing
