Leviathon wrote:Last Question - Looks like the hole coming into the boat for the shaft, don't know the technical term for it, is about 1 1/2 inches I.D. That does not leave a lot of room for a 1 1/4 shaft. Any issues running a larger shaft through there? Want to go from 1 to 1 1/4 to run a larger prop.
The rule of thumb for shaft log clearance is no less than 3/8" over the diameter, however, I believe the Marinettes use the same shaft log for 1" and 1.250" shafts.
