Outboard Motor Brackets
Rockxx
Postby Rockxx » Mon May 30, 2016 5:52 pm
FYI
In the past, a couple of forum members had mentioned converting from inboard to outboard power. Checking Chattanooga Craigslist today and found listed, two stainless steel outboard motor brackets for $ 900.00 each or $ 1,600.00 for the pair. Factory made by Armstrong out of Florida. Gent had twin 225 Mercs mounted and went with three motors so changed mounts.
Says they're rated for up to 300 HP. Wouldn't think you could build stainless brackets for that amount..would've posted the link but not smart enough to know how.
Regards to all,
Rockxx
1972 28' express "Safari"
Single Chrysler 318
Center Hill Lake, Tennessee
Re: Outboard Motor Brackets
Postby javalin390 » Mon May 30, 2016 8:05 pm
I Googled Armstrong outboard motor mount, and it comes right up. looks like it would be an interesting idea for a repower on a smaller M
nonferrous
Postby nonferrous » Fri Aug 05, 2016 12:29 pm
A while back, a member posted pic's of an outboard conversion. He said that it was working fine and seemed to make sense.
What he did was fabricate a mount that was incorporated into the swim platform without a lot of complications, it was very simple and looked strong. The pictures may still be on the servers someplace if you knew how to look.
This has always been in the back of my mind. The boats are built to last 100 years, but the Chrysler drive lines have a lifespan that gets harder and harder to keep happy, the older they get.
Think of the fuel and gear you could carry if the engine bay was empty
Intothemystic
Postby Intothemystic » Sun Aug 07, 2016 7:59 am
Looking for info on outboard conversion , aft cabin 39' with 454s want to loose big blocks shafts props rudders skegs add 3' transom extention with 12 ''' hi jacker ; will twin300 suzukis put me on plane and what rpm will I be able to back off to and stay on plane
Chuckthediver1
Postby Chuckthediver1 » Wed Dec 27, 2017 8:26 am
That's what I want to do any help is appreciated
