what to do when railing screws are stripped out
Roger2
Re: what to do when railing screws are stripped out
Post by Roger2 »
Jeff, I guess I don't understand. Did you have to get to the back side & use an extra nut to smash the threaded rivets?
Roger
Roger Brown
Petersburg, IL
Can't find the sketch I made.
Study the right photo. That small piece of metal (4 x 2 inch) with a hole drilled in one end is the "handle". The Allen bolt goes into a nut, then through the "handle", then into the Rivet Nut.
Place the Rivet Nut, handle and bolt assembly in the hole in the deck, hold onto the "handle" so it won't turn and tighten the nut (on the Allen bolt. Sometimes you'll need to also have to stop the Allen bolt from turning until the Rivet Nut starts to seat.)
It's far easier to do than to describe!
ukester
Post by ukester »
I was looking at buying either a electric gun or a riveter that has very long handles. I am thinking that I will be installing a lot of these-what size did you install 1/4?
mark ucakar
Jeff,
This the drawing you mentioned?
Railing rivet install process
tundrarules
Post by tundrarules »
Video is worth a million words :D
http://youtu.be/3Og-tHIR_0I
Rivet nut install
1985 29 Sedan
Edelbrock 1409 carbs
Mallory distributors
780 hrs/eng
TN River, MM 213.8
:mrgreen:
Rob
Post by Rob »
Helpful video, Thanks!
1973 32' FB Express
Cincinnati, Ohio
jtalberts
Post by jtalberts »
So from reading this, I am guessing that replacing the current screws with Stainless is a big No No?
41x14
"Figment"
They've always been stainless. The RIvet Nuts are aluminum with stainless bolts.
PS: Ten years without a single railing bolt failure after going to Rivet Nuts.
seef158
Post by seef158 »
What is everyone using underneath the railings Or other items mounted to your decks? Replace the old rubber with some type of new rubber insulator or just some 4200 or 5200 sealant? I will be pulling railings to paint as well as mounting some new lights at some point in time....
forest lake, mn
Duluth, mn
Washburn, wi
I believe Jeff posted years ago that he (or perhaps it was someone else) used a few nylon washers around the bolts ( between the bottom of the rail feet and the deck). Separating the rail feet and the deck allowed water to ran through, not getting trapped and causing corrosion. The washers sealed the penetration so water leakage into the hull was prevented or at least made insignificant. Seemed pretty sensible to me.
By the time I read this, I had gone the other way, using 1/8 rubber gaskets I cut to fit myself from a large sheet of rubber or neoprene. I was not motivated to remove hardware and use the nylon washer system.
