Bow Hatch
Re: Bow Hatch
Postby ddependo » Wed Mar 01, 2017 11:33 am
I just set on top of screen. Screen holds it in.
Re: Bow Hatch
Postby shade2u2 » Wed Mar 01, 2017 1:00 pm
Ours has a cushion that is tucked in the hatch opening. It's covered with the same material as our curtains. I thought the previous owner did it for insulation purposes since he ran the AC a lot. I have not experienced any condensation around the hatch but have some up toward the roof corner of the berth once in a while. The cushion did have some minor mold on it at the end of the season so there must be some moisture trapped in there.
I have not used the hatch but plan to this year.
1984 28 Express Hardtopw/single 360 1.5:1 drive (SOLD)
Jeepowell
Re: Bow Hatch
Postby Jeepowell » Sun May 14, 2017 8:04 am
Foam plug under the hatch worked for me. I made it tight to hold in place. Place something in between layers to use as a pull tab to get it back out.
37' Marinette
360s
Aurora IN
Red5
Re: Bow Hatch
Postby Red5 » Wed May 02, 2018 6:35 am
All of this is great but what do you do on the nights that you are sleeping in the forward birthing area? Nothing like a solid drop of water on your forhead while trying to sleep. ;)
Re: Bow Hatch
Postby EWRice » Wed May 02, 2018 11:42 am
Something I have considered, since I will be pulling my hatch out and blasting it, is to have the underside sprayed with a thin layer of closed cell foam, or urethane (think truck bed liner). I think the foam would work best and could be shaved down and painted to the point that it may only be noticed by the careful observer, but I fear my kids will stab it with all kinds of random things. The urethane would look good, can be tinted any color and sprayed on smooth. It may give just enough insulation to stop the problem.
barefoot99
Re: Bow Hatch
Postby barefoot99 » Wed May 02, 2018 4:23 pm
Just insulate it Temperature difference is the condensation cause, and always will be. As dependo said a thin piece of insulation on top the screen will do the trick.
SUP !
1982 32 Sedan FB
2028 hrs
360's(rebuilt)-Edelbrocks, MSD
Norris Lake
Speedwell,TN.
