Engine oil
Ryan
Engine oil
Postby Ryan » Tue Oct 07, 2014 3:15 pm
Just purchased my first Marinette and it has a set of 1986 Chrysler 360s. What motor oil do you guys recommend? The motors have about 800 hours on them...
Chrysler 360's
Cleveland, Ohio
Re: Engine oil
Postby GB49 » Tue Oct 07, 2014 6:52 pm
We have always used 30W detergent. Just last year I added a smidge of Motorkote into each engine. So far so good.
http://motorkote.com/
-Karl
1986 Sedan 32'. Twin Chrysler 360in^3, 275hp, with K&N flame arrestors
Supersport18
Re: Engine oil
Postby Supersport18 » Wed Oct 08, 2014 7:33 pm
Valvoline 30w. Engines are clean as a whistle inside and just made a 136 mile trip down the west coast of Michigan with 1200 hrs on them.
1986 Sedan Flybridge
Twin 318 closed loop
" Little Martha"
Traverse City,Mi
Autopilot (both helms)
MustangCP3
Re: Engine oil
Postby MustangCP3 » Fri Oct 10, 2014 9:01 am
On all my oil changes, I add a teflon coating additive which helps reduce heat, adds to the engine block a teflon coating to reduce wear and friction to help the engines last longer and run cooler as which all that help with better fuel mileage. One brand that both my late father and I did research on is Greesed Lighting brand we found to be the best of all of them. Greesed Lighing has other engine care products that I have used as well, but on every oil change i add this product to ALL my engines from small lawn care product engines to my cars including my boats. I use Syntec Edge Castrol Oil in the 30 w range depend on each engines I am adding the oil change to Here is a link in case you are interested in this teflon coating additive toyour engines: http://www.greasedlightning.com/shop/details.asp?id=22
barefoot99
Re: Engine oil
Postby barefoot99 » Mon Oct 13, 2014 9:14 pm
A lot of people have recommended that I use Brad Penn oil , especially with a non roller cam. It has something to do with the new oils do not contain the zink(?) that the older oils did. I like the synthetics in other applications , less heat generated and better lubricity.
FastJeff or any of the older racers have any input on the newer oils . :?: I am not sure myself, but I do see a lot of The Brad Penn oils in high HP boats and cars. Is it worth the extra $$$. People at local dirt track swear by it . I did notice my engine rebuilder used Brad Penn 30w break in oil in my new motors.
SUP !
1982 32 Sedan FB
2028 hrs
360's(rebuilt)-Edelbrocks, MSD
Norris Lake
Speedwell,TN.
Re: Engine oil
Postby barkleydave » Tue Oct 14, 2014 10:47 am
Been running Shell Rotella 10-40 for 10 years no issues.
Ryan
Re: Engine oil
Postby Ryan » Tue Oct 14, 2014 11:01 am
Rotella? Is that diesal engine oil?
Chrysler 360's
Cleveland, Ohio
newendeavor
Re: Engine oil
Postby newendeavor » Tue Oct 14, 2014 12:46 pm
I 'm a firm believer in Rotella 30W for over 10-15 years in my 502ci's.
New Endeavor
1991 41ft Aft Cabin
Louisville,Ohio River
bruegf
Re: Engine oil
Postby bruegf » Wed Oct 15, 2014 6:08 am
Mobil 1 10w30. Been using it since before it was generally available, was buying it by the case from the Mobil office at a gasoline storage facility.
Talked to a guy at Marysville Marine once and he mentioned they had a customer that had a fleet of rental houseboats that used Mobil 1 in their gensets and routinely got 10,000 hrs between rebuilds.
Fred
Re: Engine oil
Postby tundrarules » Wed Oct 15, 2014 10:04 am
Great question... Always a hot topic!
Quote by the famous fast Jeff "
For two reasons--additives and age--I recommend Shell Rotella 10W40 oil. (Just bought some yesterday from Wal Mart. It's on sale for 12 bucks a gallon, by the way.) This oil has ZDDP-type additives that protect your cam and lifters where today's "normal" oils do not (thanks to most new cars having roller lifters and overhead cams)"
Also recommended that you add extra zinc using 1/4 bottle per engine of Lucas engine break in oil additive.
http://lucasoil.com/products/engine-oil ... -zinc-plus
Or add ZDDP plus... Not much..Read directions. Too much zinc is also bad. Think we only need about 1300ppm. Remember Rotella has 1200 ppm already.
http://zddplus.com/
Not sure about all the overpriced magic oil on the market. The Rotella oil with added zinc makes the most sense to me for now. I definitely would not use synthetic oil... Too slick for our old seals and rings.
Sam's sells 15w-40 Rotella (1200ppm zinc) for $73 a case (6×6gal)
Amazon has good price on ZDDP.. Free Ship.. Hard to find in auto stores.
Here is an article on on ZDDP...zinc http://blog.hemmings.com/index.php/2012/10/18/tech-101-zinc-in-oil-and-its-effects-on-older-engines/
Let us know what you decide to use. :shock:
