Pertronix D241801 install
bobv
Re: Pertronix D241801 install
Post by bobv »
Connect the tachsto the negative side of the coil.
Bob
jmonday
Post by jmonday »
Tach is to net side. On the old dizzy I took the tach out completely to rule it having an impact out. I really think it's going to be a cap rotor or pickup problem. Dizzy bearings and all look good.
Jeff Monday (Blue Mondays)
Lower River rd
Rabbit Hash KY
For those of you who don't speak Aussie, a "dizzy" is a distributor, Mate!
G-day.
Fast Geoffrey
Oh, I thought it was a Blonde.
Ah hah!
PS: The 'Admiral' is a blonde.
Tranquilo
Post by Tranquilo »
Used the under cap conversion kit rather than the full distributor replacement (because of the fit issue described in earlier posts)
So far, it has made a big difference.
The correct part number for the 318 is: 91581
http://www.summitracing.com/parts/pnx-91581
jmonday
Post by jmonday »
That's really odd my ignitor 2 that came with my boat was cut like the photo. I ordered the same part number 1581 and had to cut it the same way. My thing that spins round and make fire 8 times per revolution ( assie for dizzy) has been sent to pertronix maybe they can solve the mystery.
Lower River rd
Rabbit Hash KY
pfhlaw
Post by pfhlaw »
My original port distributor wobbled and would not allow me to set idle below 1000 rpm. Installed pertronix dizzy but I was using wrong mark on flywheel to find tdc on #1 cylinder. Motor was backfiring and spitting fuel out of carb. Finally figured it out and now it purrs like a kitten.
NIMBUS II
1981 32' sedan bridge
New Buffalo, MI
Good lad!
