cushion foam smell removal
RustyBoat
Post by RustyBoat »
Anyone have any suggestions for removing the smell from the foam inside the cushions? My boat had a mildew problem when I got it and the room im currently storing the cushions in stinks. Im afraid after I rebuild the whole interior they will bring the smell back into the boat.
1968 32' Fisherman
Lake Sidney Lanier
Re: cushion foam smell removal
If a soaking in a bleach/water solution for a couple of hours (then rinsing thoroughly) doesn't do it, chuck 'em. The mold is probably ingrained throughout the foam.
You could try setting them outside in the direct sunshine. :|
Remove the covers first. :D
Although I haven't seen the sunshine here for two weeks. :roll:
barefoot99
Post by barefoot99 »
I tried all of the above, even did the ozone clean ( buddy has a fire restoration co) . Nothing worked very well . Wound up getting new foam the next year. You may have better luck than I did. Keep us posted . -Scott
SUP !
1982 32 Sedan FB
2269 hrs
360's-Edelbrocks, DUI
Norris Lake
Speedwell,TN.
Supersport18
Post by Supersport18 »
http://kanberragel.com/
Try this stuff. It's a little pricey so shop around. Used it the last 2 seasons. Boat smells awesome. I think I bought it a t Jamestown Distributors.
1986 Sedan Flybridge
Twin 318 closed loop
" Little Martha"
Traverse City,Mi
Autopilot (both helms)
Docsnow
Post by Docsnow »
Rustyboat here's one way not to start them from stinking stand up before U FART :D
RustyBoat
Post by RustyBoat »
HA! This smell doesnt smell that bad but it does stick around longer! :lol:
1968 32' Fisherman
Lake Sidney Lanier
Docsnow
Post by Docsnow »
Next thing put charcoal in pie plates it'll take the smell out this works :!: :!: :!: :!:
Norm reminds me that a fairly good odor absorber may be "activated" charcoal, available at fish hobby stores or other pet stores. It's sold as useful to take odors and gases out of aquarium water. I had an odor problem on the boat once (rotted bait) and it may have helped (or the odor disappeared on its own -whop knows?). It comes as little pieces of about fingertip size (as opposed to the larger pieces that are used for grilling) that present more surface area to absorb odors. You can google it to find a source.
In your case, circulation of fresh, dry air is important.
All that said, you may have so much mold in those cushions no odor stuff will do the job until the mold is destroyed or the cushions deep sixed.
RustyBoat
Post by RustyBoat »
great idea on the activated charcoal. I have fish tanks so I have plenty of that stuff. I might try putting it in a filter sock then setting it behind a fan to help filter the air in the room.
1968 32' Fisherman
Lake Sidney Lanier
