Voltage Regulator
wschneid
Voltage Regulator
Postby wschneid » Sat Oct 03, 2020 9:10 am
I have a 1986 Marinette 32 with the twin Chrysler 318 engines. One engine (alternator) is not charging. I had the alternator checked and it was okay. so I'm thinking it is the regulator. What type of regulator would it be? (part #, model) and where would it be located?
wschneid
Re: Voltage Regulator
Postby javalin390 » Sat Oct 03, 2020 4:32 pm
Chrysler part # is 2847527, NAPA # is SME185710. Not sure where they are located on the 80's models. I do know that on the 70's models, they were wired thru the oil pressure switch, so if the oil switch went bad, the reg will not turn on.
wschneid
Postby wschneid » Sun Oct 04, 2020 7:50 am
javalin390 wrote:Chrysler part # is 2847527, NAPA # is SME185710. Not sure where they are located on the 80's models. I do know that on the 70's models, they were wired thru the oil pressure switch, so if the oil switch went bad, the reg will not turn on.
Thanks.
Tuggle
Postby Tuggle » Sun Oct 04, 2020 11:18 am
Converted mine over to one wire alternators from Arco Marine, internal regulators, never looked back.
Postby bill » Sun Oct 11, 2020 8:16 am
The location of the regulator is under the black plastic box at the rear of the engine. ;)
ps
Please add a signature to your posting. ;)
USCG Master Lic. Retired
Tuggle
Postby Tuggle » Sun Oct 11, 2020 6:11 pm
Think Arco also sells a regulator, and yes it's under the black plastic cover, on the backside.
wschneid
Postby wschneid » Mon Oct 12, 2020 7:52 am
Thanks guys. I got it now.
Bill Schneider
