The 26' project
Posted: Sat Jun 06, 2015 3:19 pm
by Jeepowell
I have a stripped 26' hull, two new marine small blocks and a very small IQ.
This is the plan.
1. Go from a single screw to twins.
2. Extended the hull 4' and build a "Sea Ray" style "built in" swim platform with steps down from the aft deck.
3. Move engine aft as little as possible, to get the props under the new hull extension with new rudders.
4. Redesign the cabin/aft deck to 21 century, move head forward and make it wet, new galley and larger dinette table area.
5. Long list of things not covered in 1-4
Not the goal, but I think "if" it gets "completed", it will be the fastest Marinette on the water, guessing 60mph
I KNOW THIS IS NOT A GOOD IDEA, it would be much easier to buy another boat, so lets leave those comments out.
where I would like help is with the hull extension and convertion to twins, has anyone done this, links to helpful sits, anything anyone can think of?
Re: The 26' project
Posted: Sat Jun 06, 2015 7:08 pm
by Roger2
Interesting. Hope you or a good friend is a good al welder. Keep us posted. Look for one to be cut up for the struts, rudders etc buy the back X feet.
Roger
Re: The 26' project
Posted: Sat Jun 06, 2015 8:59 pm
by Jeepowell
Thanks Roger,
I have already pulled everything I could get from a 32' that got scraped, but the struts may not work, because I am going to work prop tunnels into the extension design.
Re: The 26' project
Posted: Sun Jun 07, 2015 4:48 am
Whoo-boy! Are you ambitious!
Love to see photos of that project.
Re: The 26' project
Posted: Sun Jun 07, 2015 3:55 pm
by bcassedy
I don't think you'll see anything but admirable comments for the level this project involves. Wish you best of luck.
You may have already checked into this, but could the prop shaft tunnels on the scrapped 32' have worked?
Re: The 26' project
Posted: Sun Jun 07, 2015 9:00 pm
by RiverRatt
To help with the design to install the twin engines, look at a twin. Take pictures and measurements and reverse engineer it to a 26'. I know one you can examine. I should be in the water near your house by the end of week.
Re: The 26' project
Posted: Tue Jun 09, 2015 10:23 pm
by Jeepowell
Bill, Marinettes don't have prop tunnels, are you thinking of shaft logs? A prop tunnel is recess in the hull to get a better shat angle and less draft, shat log is the tube that the shaft goes through the hull.
Re: The 26' project
Posted: Tue Jun 09, 2015 10:24 pm
by Jeepowell
That is the plan River Rat, need to look at the bottom of yours before it gets wet.....lol
Re: The 26' project
Posted: Wed Jun 10, 2015 5:56 am
Why not? Somebody converted one to outboards, remember? Was tempted to do the same thing more than once!
Re: The 26' project
Posted: Wed Jun 10, 2015 3:46 pm
by bcassedy
Jeepowell....
Yeah, that's what I meant. Right thing, wrong description. :oops:
