Fuel System Restoration: Tanks to Carbs...
carl
Post by carl »
carl
Re: Fuel System Restoration: Tanks to Carbs...
Post by carl »
carl
Post by carl »
I hope you glued those rubber strips to the tank with 5200 adhesive.
carl
Post by carl »
ddependo
Post by ddependo »
As I watch Carl's progress it is amazing to see the craftmanship he has put into this 32. It is going to be much better than factory when he gets done. He does everything the right way the same as he would at work for Westinghouse on a power plant. He doesn't get in a hurry. I couldn't even pull him away to go for a boat ride and dinner. It has been a educition being on the same dock . Nice guy.
Glad to see you're retaining those Perkos--darn good unit. I use a small mason jar to drain them and check for water/ crud.
carl
Post by carl »
When I changed the gages in mine, I deliberately set them up so there was at least 10 gallons of gas in the tanks on 'E'. I know; it's only a psychological thing, but it helps when the marina is a long way off.
ddependo
Post by ddependo »
I did that too. Have not run out yet.
