Kicker motor
Kicker motor
Just wondering whats involved and how practical it is to possibly install a kicker motor on the swim platform.
If a big enough motor would fit would it be good for cruising longer distances saving fuel and wear on the V8 motors?
If it could get up to 6 to 8 knots or so running at low enough rpm that might be a nice option to extend cruising range.
I seem to remember a post years ago where someone was going to beef up the swim platform and install two outboards and do away with the stock motors altogether. I wonder if that ever came to fruition.....
My boat is a 1987 32" FB
Re: Kicker motor
You would need a 20-25 hp kicker to be able to move the boat 6-8 mph. It would use less fuel than the v8's, but that little motor would be screaming away and probably get annoying after a little bit.
Re: Kicker motor
Someone converted their big M to outboards, but they had to massively beef up the transom.
Not sure an outboard would deliver superior mpg with those two props dragging in the water. Seriously; and it'd have to be a 4 stroke OB at the very least.
Re: Kicker motor
I wonder what the performance with a couple 35 horsepower outboards that were slightly over propped would give you if the V8 motors and props were removed. Certainly would be a lot lighter.....
Just thinking/wondering at this point....never gonna happen to my boat in reality.....ive got 2 good motors and kinda like going fast sometimes...
It would be interesting to see what would give 8 to 10 knots and long distance cruising ability without going deisel
Re: Kicker motor
Mercury does have outboard diesels btw. Not sure they are any good though.
Re: Kicker motor
It have often wondered what a pair of Honda 50 FS outboards would do in a great loop setup with a huge center fuel tank for long range.
Re: Kicker motor
We have a Honda 60 on a MacGregor sailboat with no mast, which is 26' long and 7.5' wide and weighs about 3500 lbs loaded. At 3000 rpm it pushes the boat 8 mph. It has a 14 inch X 9 pitch prop. Max speed empty with 2 people is 20 mph, loaded max speed is 12 mph. At 8 mph it uses 1 gph at max loaded speed of 12 mph it uses 5 gph. We did the great loop in 2016 on the MacGregor. Hope this is helpful with your question.
Richard
Richard
Re: Kicker motor
Sailboat speeds are very much governed by hill design - not by motor power alone
Re: Kicker motor
Mercury Diesel Outboards are not offered in the US market due to EPA regulations.
Re: Kicker motor
One of the guys on the Marinette Facebook page posted this video awhile back. It's a 9.9 hp outboard mounted to the swim platform for fishing/trolling. He got about 2 mph out of it.
https://www.facebook.com/bryan.oetting/ ... =2&theater
Not sure if the video will open properly if you are not a member of that particular FB page. Seems to be a nice setup though.
I am considering one day adding a 25hp kicker as a "get home" motor since I have a single engine boat.
There's also this link to a post from an
owner who repowered with a 200hp Yamaha. I remember him reporting that it performed very well. Click the link and scroll down a little bit for a picture.
viewtopic.php?f=6&t=221&p=3890&hilit=ou ... ower#p3890
Maestro
1986 32' Sedan
Chrysler 360s
1.5:1 Gears, 16x16 props
1970 28' Express
Single Chrysler 440
1:1 Gear, 14x12 prop
Green Bay, WI
1986 32' Sedan
Chrysler 360s
1970 28' Express
Single Chrysler 440
Green Bay, WI
