electronics upgrade
fighterpilot
electronics upgrade
Postby fighterpilot » Sun May 14, 2017 4:55 am
Officially have contract on the Marinette 37 sedan. Present electronics a Eagle 6100 so will need to upgrade. Are there transducers today that will work thru the aluminum hull, or will I have to drill a hole and mount it. Any suggestions, would like at least 9 inch display and at both stations. Thanks, Ray
Re: electronics upgrade
Postby Fastjeff » Sun May 14, 2017 6:17 am
I used a transom mount on my 32 footer and was never sorry. Had to buy the Humminbird extension cable ($$$) to do it.
Postby barkleydave » Sun May 14, 2017 7:29 am
Alumaducer makes shoot thru transducers that they claim will work on our M's. I have not tried on and like most use a transom mounted setup.
https://shop.vexilar.com/en/accessories ... --tb0023au
fighterpilot
Postby fighterpilot » Tue May 16, 2017 8:24 pm
With a transom mount on inboards doesn't the prop wash cause problems with all that turbulence. ?? Do you mount it in center between the output from the two props. ??
Postby TinLizzy » Wed May 17, 2017 11:41 pm
I have two transom mounts located between the engines. They work fine to about 7-8 mph, then the turbulence makes it hard to pick up fish. But I can usually track bottom up to full cruise speed of 27-28 mph.
1975 28 Express-Twin 318 Raw Water cooled
Portage Canal Waterway-Lake Superior
fighterpilot
Postby fighterpilot » Thu May 18, 2017 12:42 pm
Need to be able to find fish while running around in the Gulf. We head for a marked spot and than need to see if any fish on it today and on the way to the mark also like to keep an eye out for fish. Guess I will have to cut a hole or two. Darn. Thanks.
Postby jralbert » Thu May 18, 2017 8:55 pm
Just recalled this: Airmar makes xducers for most mfr's of fishfinders. Call em to see whether there's one for your unit that will shoot thru aluminum.
fighterpilot
Postby fighterpilot » Sat May 20, 2017 3:26 pm
Will check with Airmar. Thanks
Return to “Electrical and Electronics”
Who is online
Users browsing this forum: No registered users and 1 guest
