I recommend the 3/16 packing. Much easier to install, and it MIGHT cure your weird problem.
Boat in the wet, but shafts won't drip
Re: Boat in the wet, but shafts won't drip
- Member
Thanks Jeff,
Will do.. I'd rather have to repack more often than burn up shafts that are in good shape.
C & K Johnson
1980 32 Sedan
Twin 360's "Pour Choices"
SE Michigan
1980 32 Sedan
SE Michigan
Just in case you weren't aware (and if you are, my apologies), the mating flange surfaces between the shaft and the engine should not be off by more that .003 of an inch. Ie. if you can get a .003" feeler gauge to slide between the flanges easily, there's a misalignment.
- Member
Yep. I did know that and will be checking yet again once I re pack the shafts. Appreciate the knowledge though. Better to be told twice than never
C & K Johnson
1980 32 Sedan
SE Michigan
1980 32 Sedan
SE Michigan
- Member
Success! 3/16 did the trick. 4-6 footers today, but it dripped in gear at the dock and not in neutral
C & K Johnson
1980 32 Sedan
SE Michigan
1980 32 Sedan
SE Michigan
Alright!
Outstanding!!
Now, boat like there's no tomorrow....
... or until the end of the season!!!
- Member
Yep now to see if the new plugs and wires cured the popping out the carb over 2k on starboard...once the wind dies down
C & K Johnson
1980 32 Sedan
SE Michigan
1980 32 Sedan
SE Michigan
I had a simular problem years ago with GFO packing. I finally went to 2 rings and have had no problems for 10 years maintaining a drip rate.
The GFO can run with very little drip and still run cool.
