Fuel for thought
Posted: Fri Aug 08, 2014 10:24 pm
I have a Cummins 4BT I picked up in a trade for a couple of truck axles, I have next to nothing in it, and it needs a home, one of my old trucks or my boat. I could possibly trade it for a 6BT to a friend for a little money. It came out of a bread truck and it has the Chevy engine bell, find a GM bell, coupler for the velvet drive and I'm set, (the GM engine bell will fit the 6BT if I decide to trade).
Building the components (exhaust manifold etc.) to make it work for marine service is not an issue, I enjoy building things.
The diesels are expensive and they are a pain in the a$$ to install subject has been beaten to death, performance and components needed has not.
Most of my cruising with my current single 318 is around 10 MPH at 2,000 RPM, the 4BT would be lower RPM at 10 MPH than the 318 , but I believe it would suffer on the top end. I don't want to run on the governor all day and burn it up.
Anyone have a 4 or 6BT and have any fuel mileage, RPM, speed numbers? (I've heard twice the mileage and twice the speed, with a 6BT)
Would a 1:1 tranny work or would you need a 1.5:1?
Would the 71 Borg Warner be heavy enough or would you need a heavier tranny?
What size shaft would you need?
What size, pitch prop would you use with either tranny?
This is not a for sure thing for me, more of the pros and cons, something to think about. Let's take a look at the advantages, disadvantages of diesel and gas, excluding the money and work needed to do the swap.
