Starter
bwired9
Starter
Post by bwired9 »
Is there a replacement for the stock starter?
BlueSkye
Re: Starter
Post by BlueSkye »
I took mine to a local rewind shop and had it back in a few days.
1971 32ft Express 2x318
Re: Starter
The original Prestolite starters have to be rebuilt. I believe Arco makes a new version of the Delco starter. I also believe there is a pmgr (gear reduction) available. I will see if i still have the part numbers.
Re: Starter
Post by Tuggle »
Arco makes a direct replacement, standard and reverse rotation.
bwired9
Re: Starter
Post by bwired9 »
Thanks guys, I'll look at Armco.
BlueSkye
Re: Starter
Post by BlueSkye »
Did I mention that having mine rebuilt was less than $100?
ukester
Re: Starter
Post by ukester »
Ebay
mark ucakar
bwired9
Re: Starter
Post by bwired9 »
The problem I'm having is that when I try to start the starter will turn the engine very slowly then stop! I've had starter rebuilt, replaced starter relay, new batteries, removed and cleaned all battery cables! What's else can I check or replaced!
Re: Starter
Check the flywheel ring gear. I have seen 5 come loose in the last 2 years on chryslers. There should be no gap between the gear and the flywheel.
pbaker32s
Re: Starter
Post by pbaker32s »
bwired9 wrote:The problem I'm having is that when I try to start the starter will turn the engine very slowly then stop! I've had starter rebuilt, replaced starter relay, new batteries, removed and cleaned all battery cables! What's else can I check or replaced!
Check for water in the cylinders.
Maybe Trying to hydrolock due to leaky intake,exhaust or head gasket.
