318/392 Stroker Motors
barefoot99
Re: 318/392 Stroker Motors
Postby barefoot99 » Wed Jun 10, 2020 9:00 pm
:D :D :D :D :D
Trowerpower wrote:Blue Sky back in the water, port engine repaired. Mechanic ran it she turned 4100 rpm with throttle left, not sure on the speed. New bottom paint and the 4 blade props installed. She is pretty stripped presently. Give me few days to sort out minor issues and will post engine rpm/speed numbers.
SUP !
1982 32 Sedan FB
2072 hrs
360's(rebuilt)-Edelbrocks, DUI
Norris Lake
Speedwell,TN.
Trowerpower
Postby Trowerpower » Thu Jun 25, 2020 3:47 pm
So full of water, eisenglass, full of fuel, curtains all the stuff 26mph at 4,000 rpm. Clean bottom.
Trower Power
Blue Sky
Performance Distributors
750 Edlebrocks
fresh water cooled
1.5 to 1 velva-drives
Onan 6.5kw gen set
Trowerpower
Postby Trowerpower » Fri Jun 26, 2020 8:43 am
1600rpm 10mph, 3,000rpm 20mph.
Trower Power
Blue Sky
750 Edlebrocks
fresh water cooled
Onan 6.5kw gen set
Postby Fastjeff » Fri Jun 26, 2020 12:15 pm
Sounds to me that you need a lot more prop! My 32 footer did 20 mph at 2,500 rpm (and still leapt out of the water).
More prop equals better mpg and less engine wear.
pbaker32s
Postby pbaker32s » Sun Jul 05, 2020 5:54 pm
What props are you using ? I have 16x16 3 blades as came factory. I can never remember the speeds /rpm‘s so I took some pictures this weekend . 7 people aboard full tanks top on.
I have seen 34 mph. Around 4200 rpm’s
Trowerpower
Postby Trowerpower » Tue Jul 21, 2020 3:10 am
Presently 15 x 14.25 four blade props. I believe it is under propped slightly. I am having the original props reconditioned. I still working with Delta Propeller for a different set.
Trower Power
Blue Sky
750 Edlebrocks
fresh water cooled
Onan 6.5kw gen set
Postby Fastjeff » Tue Jul 21, 2020 7:27 am
Whoa! You're way under propped. My stock 360s (32 footer) were happy with 17 x 15 4 bladers.
More power means lots better gas mileage and less engine wear as well. The boat still rocked out of the water with them, turning 3,900 rpm WOT.
