Engine alarm sounds when both engines are running
Posted: Thu Aug 14, 2014 10:13 pm
by Louky
Yesterday I started both engines, flipped the engine alarm switch and it went off. I looked at the tach's and both were running. Does anyone know what I should check first?
Thanks for any help.
Louky
Re: Engine alarm sounds when both engines are running
Posted: Fri Aug 15, 2014 8:59 am
by Roger2
My first step would be to get a mechanical oil pressure gauge & make sure you have oil pressure on both.
Roger
Posted: Sat Aug 16, 2014 9:01 am
by tundrarules
Look at both oil press sending units for corrosion. Take one wire off at a time to see which swith is bad. Hopefully u don't have a grounded wire..I don't think so since your oil press guage is working. Let us know what u find.
Posted: Sun Aug 17, 2014 6:20 pm
You need to remove ALL of the alarm connections (Oil pressure and temp switches) on both motors. Then, with both running, put them back on one at a time until the alarm goers off.
Pain in the tush, but that's the best way.
PS: All 6 of my temp switches use automotive style quick disconnects to make this task easier. I also separated the two motors alarm system so I can run either one alone (without the low oil pressure alarm on the other setting the alarm off). This required two simple relays and a bit of wiring. If anyone is interested, I can post photos and the schematic.
Posted: Mon Aug 18, 2014 9:01 pm
by Louky
A friend who seems to know engines helped me troubleshoot it. He disconnected the engine contacts, checked some fuses and grounds. At this point he thinks it's the alarm itself going bad. I've ordered a new one which will be in soon. I'll post the results.
Thanks so much for the replies. Very helpful.
Louky
Posted: Tue Aug 19, 2014 6:56 am
by Louky
Jeff, separating the alarm systems sounds like a good idea and would be great info to have on the forum. Please post the how to if it's not to much trouble.
Thanks!
Louky
Posted: Tue Aug 19, 2014 11:18 am
No problem. I use a couple of simple relays I go on eBay (about ten bucks).
Here's the wiring diagram.
Posted: Tue Sep 30, 2014 6:48 am
by Louky
Thanks Fastjeff for posting the diagram. That looks like a good project for the future.
As it turns out, it wasn't the alarm itself. After installing a new one the problem was still there. I disconnected all the leads as suggested and found that it was the alarm sender on the port engine. Super easy to replace and it now works as it should.
Problem solved. Sorry it took so long to get back to this post.
Thanks all
Louky
