Engines ready to install, Finally!
Leviathon
Postby Leviathon » Mon Feb 19, 2018 5:51 pm
Alright, both engines are together and running. Any leaks have been repaired. Now working on engine compartment getting it ready! :)
Steve and Mary Levi
1973 32' Marinette Fisherman
Twin Chrysler 360's
El Ohssa
St. Joseph, Michigan
ThunderStruck
Re: Engines ready to install, Finally!
Postby ThunderStruck » Mon Feb 19, 2018 6:56 pm
Nice !
hightension
Postby hightension » Tue Feb 20, 2018 5:52 am
Looking good
Rodney Hack
Louisville,Ky
mgoblue9798
Postby mgoblue9798 » Wed Feb 28, 2018 4:05 pm
Nice. Did you get remans, or did you to through them yourself?
Leviathon
Postby Leviathon » Wed Feb 28, 2018 5:44 pm
I tear them down, machine shop does all of the work, then I put them back together and hope for the best! I am from a generation that rebuilt the engines in the cars we drove several times over! Small Block Chevy's are pretty simple
Steve and Mary Levi
Twin Chrysler 360's
El Ohssa
Postby Fastjeff » Thu Mar 01, 2018 6:36 am
..." I am from a generation that rebuilt the engines in the cars we drove several times over!"
Ditto! Good luck.
Tuggle
Postby Tuggle » Thu Mar 01, 2018 9:37 am
Did you have your transmissions rebuilt too?
Leviathon
Postby Leviathon » Fri Mar 02, 2018 10:12 am
Did not rebuild tranny's. Just replaced fluid. Money runs out eventually!
Steve and Mary Levi
Twin Chrysler 360's
El Ohssa
Tuggle
Postby Tuggle » Fri Mar 02, 2018 11:25 am
Know that all to well, I was afraid not to have them done. Everything seemed fine but while they were out went ahead and bit the bullet.
Leviathon
Postby Leviathon » Fri Mar 02, 2018 4:12 pm
While they are out: Plumbing for head, blower motors, all wiring and battery cables, 120v breaker box, all new motor mounts, new prop shafts, props, bearings, rudders, battery boxes, all new exhaust hoses, fresh water strainers, water separators, fuel line - should I continue? Oh, and the cost to rebuild 2 small block chevy's and add fresh water cooling system. After that, the boat will still need to be stripped an painted, and aluminum tubing for rails replaced with stainless along with new bases. Also need to redo helm with gauges I can read. Would not mind a boat cover as well. Should have got into boating when I was 20, will never get all of this done!!!!!!!!!!!!!!!!!!!
Steve and Mary Levi
Twin Chrysler 360's
El Ohssa
