re wiring DC
rlambert
re wiring DC
Post by rlambert »
Getting ready to re-do most of the DC wiring in our 73 28ft express. I have at least three places where wires are grounded to the hull!!!! the aft bilge, the trim tabs ,and the fuel gauge. I know theses need to be corrected among other things. Just looking for basic suggestions to get started such as wiring size to re run the grounds to a common ground. I assume I need a ground bus bar? and please clarify....do i ground the ground bus bar to the lug on the the bulkhead or the engine? what else might i put on my shopping list as i get started?
Re: re wiring DC
Post by shade2u2 »
I don't know the origin or accuracy of this - but I found it a while back. It might have come from someone here.
Maybe it will help.
http://www.geocities.ws/dougmrose/Marin ... eneric.pdf
Re: re wiring DC
It looks like the geocities link just posted above by John (shade2u2) was created by Doug Rose. Doug used to be very active on the site and was regarded as very informed on electrical matters.
rlambert
Re: re wiring DC
Post by rlambert »
Wow that is amazing, I could have used this last year when I wired the inverter in our '32! Thanks!
Re: re wiring DC
Awesome download. I found a single page copy for M's just surfing the net, but this one is great. Thanks John
rlambert
Re: re wiring DC
Post by rlambert »
what gauge wire should i use for bilge and trim tabs?
MetalHead
Re: re wiring DC
Post by MetalHead »
Electric or hydraulic?
Big BigM 's Rule !!!
Re: re wiring DC
Post by shade2u2 »
Here is another one from the same individual about wiring a 32 with perkins diesels. It looks much more detailed. I'm no electrical guy and have not reviewed it at all but maybe it could help someone.
http://www.geocities.ws/dougmrose/32_Ma ... inette.pdf
Does anyone know it the 32 with Perkins is still running around out there?
rlambert
Re: re wiring DC
Post by rlambert »
hydraulic
railrunner04
Re: re wiring DC
Post by railrunner04 »
You never know what you'll find on a dc system once you start pulling wire I see a lot of dumbfounded head shaking in your future haha!
As far as the trim tab hydraulic pump we used 10 gauge wire Check out blue sea systems for panels if you happen to need any, really well worth the money cleans up the spaghetti of wires quite well.
Speaking of trim tabs the previous owner had wired them to the ignition power lead :shock: if you tried to adjust the tabs underway the port engine would just about die real exciting!
Moby Rick
FYC grosse ile mich
32ft F/B express
1971
T/318 Chrysler marine
