I recently purchased a 1975 28' Marinette that has a galvanic meter installed on the dashboard.
Asking what the reading should be to be considered in a safe zone? Trying to find out specifically when I need to replace the anodes.
Thank you
What should the Galvanic meter readings range between?
Re: What should the Galvanic meter readings range between?
Your meter should tell the acceptable ranges. Look at the fine print for aluminum.
Table 1. Galvanic Series Of Metals In Sea Water With Reference To Silver/Silver Chloride Reference Cell [Sea water flowing at 8 to 13 ft./sec. temperature range 50 degree F (10 degree C) to 80 degree F (26.7 degree C)]
Anodic or Least Noble Corrosion Potential Range in Millivolts
*The range shown does not include sacrificial aluminum anodes. Aluminum alloy sacrificial anodes are available that have a maximum corrosion potential of -1100 mV.
Magnesium and Magnesium Alloys -1600 to -1630
Zinc -980 to -1030
Aluminum Alloys -760 to -1000
Cadmium -700 to -730
Mild Steel -600 to -710
Please use a signature when you post.
Ideal range:
.95-1.05
numbers will vary depending on water clarity and wether fresh or salt water.
Dave
.95-1.05
Dave
- shade2u2
Mine reads .85 - .92 most of the time now. How much of a concern is this?
I added a cabled anode but it doesn't seem to change the readings. I may not have a good connection with the clip.
If you haven't done so already, clean the wire connections on the meter and see if that makes a difference. It may since the current amounts are so small to begin with. Meanwhile, imho, your readings seem pretty close to the listed rangeshade2u2 wrote:Mine reads .85 - .92 most of the time now. How much of a concern is this? I added a cabled anode but it doesn't seem to change the readings.
