Thermostat Housing
Re: Thermostat Housing
Postby bcassedy » Fri Dec 28, 2018 7:20 am
Thanks Jeff!!! :)
'88 32' Sedan Bridge
Twin 318cu in Chrysler
1.5:1 Velvet drive trannies
Fresh water only
Postby EWRice » Fri Dec 28, 2018 10:58 am
The ones I have are either '68-'74 or '86 and newer. What you need is still available new p/n 3745360. If you can't find one let me know and I can order one.
Postby javalin390 » Fri Dec 28, 2018 9:05 pm
The image of the cast housing #3745360 is not the only type used. Mine, a 1975 model, uses housing Chrysler part #E7093M, which if you google images of this type, you will see that the two nipples to feed water to the exhaust manifolds, are brass 90*s that thread into the housing. Also, if you cross reference the t-stat gasket, for example in Fel-Pro, that the gasket fits many other makes as well, like Chevy small blocks. Maybe, just maybe, a t-stat housing from a Cruisader or Mercruiser may fit. Anyone ever tried this? Not sure if any of these old t-stat housings are still available or not.
Postby javalin390 » Fri Dec 28, 2018 9:19 pm
If all else fails, you could try this place https://www.hardin-marine.com/c-124-the ... ?pagenum=1
ThunderStruck
Postby ThunderStruck » Tue Jan 01, 2019 1:54 pm
Thanks EWRice . Please let me know...
Mike Calp
ThunderStruck
1978 32' FB Sedan
Middle River,Md
