CW rotation Build
Posted: Tue Nov 02, 2021 12:23 pm
by Leviathon
Could you build a more modern CW rotation engine? Would like a 1 Piece rear main seal. I know they offer newer reman CW rotation engines -but could you do it yourself?
Re: CW rotation Build
Posted: Wed Nov 03, 2021 7:32 am
First of all, the pistons go in backasswards: the 'F' points to the rear. Never messed with the rear main seal, but I've read it has to be different somehow. Other than that, and the special camshaft, the rest of the parts are standard (even the water pump).
You set the distributor up the same way except that the firing order runs around the cap in the opposite direction. (Special gearing on the camshaft spins the distributor and oil pump in the same direction as the standard rotation motors.) And, of course, the starter spins the opposite way as well.
Good luck!
“Let’s go Brandon!”
Posted: Wed Nov 03, 2021 8:16 am
by Leviathon
Was hoping to hear from you FJ. Hope you are well! The only thing I am unsure of is the oiling holes in the crank seem to be drilled at an angle. Won't that affect they potential to lube journals? But I do not see a separate number for a reverse rotation crankshaft, and I know remanufaturers are making CW rotation builds. Also, heard you can just swap banks with pistons to achieve pin offset as opposed to moving them on existing rods. It does show there is a seal front and back for a reverse rotation engine.
Posted: Thu Nov 04, 2021 6:59 am
The cranks are identical! The rods go in either way so the pistons can face the rear.
Still not sure about the main seals. I HEARD they are different in some way but not how. Sorry.
Posted: Thu Nov 04, 2021 1:03 pm
by Harryb
Posted: Thu Nov 04, 2021 1:10 pm
by Harryb
There was talk that CW motors had the knurled spaces the seals rides on machined to sling oil inward to help with leaks. Harry
Posted: Sun Nov 14, 2021 7:39 pm
by barefoot99
Harry is correct. The CW crank has the knurling at the main seal opposite of CCW to push the oil in the proper direction. Other than that, they are the same.
Posted: Mon Nov 15, 2021 6:29 am
Uh-oh! Not sure how you can get around that.
Posted: Tue Nov 16, 2021 9:36 am
by bill
Steve,
:idea:
Lakeland Auto and Marine in Port Clinton Ohio just posted a Facebook video about this subject. ;)
His name is Chris Hamm I believe. Very knowable on Chrysler Marine engines. :geek:
Posted: Sun Nov 21, 2021 6:06 am
I guess you'll need to score a reverse rotator crank?
