Thermostat housing
Posted: Mon Apr 17, 2023 3:31 pm
by wschneid
I have an 86 32' sedan flybridge with the 318 Chrysler engines. I want to check the thermostat, but I'm not sure where it is located.
Could someone post a photo of the housing? I see a number of hoses going into a fitting with two bolts near the front of the engine. Is that it?
Any recomendations on removing it?
Bill Schneider
Re: Thermostat housing
Posted: Mon Apr 17, 2023 3:36 pm
by wschneid
I have an 86 32' Sedan Flybridge with the 318 Chrysler engines. I want to check the thermostats, but I'm not sure where the housing is located. Could someone post a photo of the location? I see a fitting forward of the carburetor with hoses running to it. Is that it?
Does anyone have any recommendations on how to remove it?
Bill Schneider
Posted: Mon Apr 17, 2023 6:25 pm
by TinLizzy
It is located at the top front of the engine right in front of the carb. Pull the hoses off, and remove the bolts. You may need to tap it with a hammer or such to get it to pop free. There should be a gasket there also.
Posted: Tue Apr 18, 2023 9:14 am
by wschneid
Thanks. that's what i thought.
Bill Schneider
