rudder removal help!
Posted: Sat Mar 21, 2015 3:02 pm
by jtalberts
So my rudders are seriously bent and I am trying to get them out of the boat. I have them torn down but I can't get them out of the base of the brass locking nut assembly. It will not rotate in the brass piece either. I might just cut the thing in half after seeing how rusted it is.
Re: rudder removal help!
Posted: Sun Mar 22, 2015 8:41 am
by bill
Youch :!:
Before you start cutting try PB Blaster and a little heat.
And DEFINITELY :lol: don't try removing rudders while boat is in the water. :roll:
and if all else fails look at this picture of a new stuffing box. :shock:
http://www.deepblueyachtsupply.com/driv ... e-assembly
Posted: Sun Mar 22, 2015 9:09 am
by ericinga
Second Bill's advice. If you have time to let is sit, use penetrating oil. You might take a chisel and lightly clean out the surface rust. This might open up a path for the oil into the joint. I'll be doing the same to our boat in a week or so. Looks like the penetrating oil should be applied now.
Eric
Posted: Sun Mar 22, 2015 11:30 am
by jtalberts
I sprayed a bunch of PB blaster on it today. I am gonna let it sit till tomorrow. If it doesn't budge, "OFF WITH IT'S HEAD!" The rudders are bent and really rusted out. I will get a couple new ones built from the guy in Dayton.
Posted: Sun Mar 22, 2015 1:33 pm
by bill
Hopefully with new non-metallic cutlass bearings :!: :oops:
Posted: Sun Mar 22, 2015 6:27 pm
by jtalberts
Those were purchased last year before I realized how much an effort this was going to be.
Posted: Mon Mar 23, 2015 6:09 am
You need to 'work it over' with a pencil grinder using sanding drums or flap wheels. Take it right down to shinny metal, and don't worry if you take a little extra off.
I pulled mine years ago, during the winter. Not a fun job!
Posted: Tue Mar 31, 2015 8:35 pm
by jtalberts
I cut them out. They are trash. Image
Posted: Wed Apr 01, 2015 6:18 am
Eeeuuuuoooowww!
Posted: Wed Apr 01, 2015 8:37 pm
by bill
[quote="jtalberts"]I cut them out. They are trash.
What were they thinking :?: :shock:
Stainless is definitely the way to go. :roll:
Philips Sheet Metal
Rob Philips - Owner
1215 Ray Street
Dayton, OH 45404
937-223-2722
tinman3065@aol.com
He was charging $100.00 :)
