440 intake
Posted: Fri Mar 27, 2015 3:31 pm
by ukester
thinking about replacing my 440 intakes with a pair of Edelbrock # 5091 Chrysler 413-440 Torker II Aluminum Intake Manifolds.
any one else done this-just checking my boat is a fresh water boat and cannot think of a reason not to do this.
Thanks Mark
Re: 440 intake
Posted: Fri Mar 27, 2015 7:16 pm
by Supersport18
I believe the marine intake is angled to keep your carb as level as possible. There might also be some safety issues involved. I would contact edelbrock and see if the intake was made to fit a marine engine.
Re: 440 intake
Posted: Sun Mar 29, 2015 5:58 am
by ukester
the carb gasket is what is angled, I cannot see how changing to this manifold would present any risk.
Re: 440 intake
Posted: Sun Mar 29, 2015 9:13 am
by MetalHead
Real question should be, will it really help?
I think if your not running WOT and not going to redo the whole top end, you may better spend your cash upgrading the ignition to burn hotter and maybe newer (jetted and tuned) 1409 carbs.
I was thinking about replacing the intakes on my 215's and found after a lot of reading that typical cruising RPMs (1800 - 2100) really did not get me much. So I went to new 1409's and Pertronix ignition. Yet to be seen how it will do, since I am building the engines now.
Of course this may be all different on the Crusader engines.
Re: 440 intake
Posted: Mon Mar 30, 2015 6:49 am
by ukester
part is why I want to replace the intakes is the 1409 does not have the same base as the intake-the intake has the larger bores in back the new carbs have the holley style base. its more than a performance issue
Re: 440 intake
Posted: Mon Mar 30, 2015 8:14 am
You have fresh water cooling, right? If not...forget it! (Corrosion.)
Re: 440 intake
Posted: Mon Mar 30, 2015 5:29 pm
by ukester
no salt water here-fresh water cooling
Re: 440 intake
Posted: Mon Mar 30, 2015 8:14 pm
by MetalHead
Re: 440 intake
Posted: Tue Mar 31, 2015 6:55 am
by Supersport18
ukester wrote:no salt water here-fresh water cooling
Fresh water cooled = closed loop cooling. Block is filled with automotive type coolant. Raw water i cooled uses seawater(salt or fresh) for the coolant. Lake water is full of minerals and dis similar metals would cause galvanic action and corrode quickly. Coolant has additives that fight corrosion. I think that is Jeff's intention.
Re: 440 intake
Posted: Tue Mar 31, 2015 7:00 am
Correct, The motor MUST have a closed system cooling with anti-freeze in the block.
