rub rail vinyl?
rub rail vinyl?
I have a 1985 39 Marinette looking for the vinyl drip rail that goes into the stainless rail around both gunnels? thanks Wally D
Name Miss Kris III
Re: rug rail vinyl? rub rail
I have seen people use a product similar to this before
http://www.ebay.com/itm/Three-rolls-1-2 ... 43d99d3fb4
You loosen the screws for aluminum or stainless rub rail and slip the vinyl between the rub rail and the gunnel (gunwale) then tighten as you go.
Works better with two people
My Marinette the rub rail is made out of aluminum.
The thinking behind the vinyl is that the water and dirt will drip off the edge of the vinyl and into the water instead of on the side of the hull thus not leaving those darn black stricks running down the hull.
There are a lot of different colors and widths available
Re: rug rail vinyl?
Where do I get the vinyl replacement? Thanks for your comments
Wally 586 725 0009
Wally 586 725 0009
Name Miss Kris III
Amazon.com Oatey 33925 Plastic Strap, Bagged, 3/4-Inch x 25-Feet
by Oatey
$6.10
or
1-800-295-5510
Uline Products
Quick Order
Catalog
Shopping Cart
Carts: Forward
Model # Description Qty Price Total Remove
S-18508
Uline Poly Strapping - 1/2" x .024" x 7,200', White
$85.00/cl
$85.00
SUBTOTAL = $85.00
Re: rug rail vinyl?
This is a vinyl drip edge that runs along the gunnel, uline sells packing materials.
Wally
Wally
Name Miss Kris III
Thats what I have seen used for this purpose
Thnks
