1991 Crusader Temperature Question for FastJeff
Posted: Sun Apr 12, 2015 9:33 am
FastJeff,
With your vast knowledge of Crusaders, got one a problem that is maybe simple but puzzling. I've just installed all new factory OEM Crusader Manifolds & Risers on my 1991 engines. These engines are in my aft-cabin and the exhausts are configured like a v-drive dumping out the front. After warm-up, my risers are 90 degrees, my left side manifold is about 175 degrees, (facing the front of the engine), and my right side at 210-215 degrees. This is using a temp gun and shooting the outside metal 6 inches behind the riser. My thermostat housing is at 160-162 degrees. Is this a flow problem with my heat exchanger, block, global warming? Stumped! Any thoughts would be greatly appreciated. Thanks, Greg
