Thanks!
Prop for my 1962 Big M
Where do I buy a prop? Althouse seems to still be out if commission. It's a 30' with AMC 327. Still in the water and I don't wanna pull it out without having a prop to put on it so I need the right prop pitch, etc.
Thanks!
Thanks!
1962 Marinette 31' Express
Single Gray Marine AMC 327
Mercury 500
1976 Saquaro Jet Boat
Ford 460
Mercury 500
Ford 460
meltonhill
Re: Prop for my 1962 Big M
Any local propeller shop should have what you need. 14x10 rh 1" tapered shaft.
meltonhill
Any local propeller shop should have what you need. 14x10 rh 1" tapered shaft. It's basically the same prop older inboard ski boats ran.
Thank you!
Mercury 500
Ford 460
Mercury 500
Ford 460
meltonhill
My buddy has a 1965 26' with a AMC 327 they're neat motors. Good luck with it. Where are you located?
I'm in Iowa. Docked on the Mississippi. What does your friend run for a prop?
Mercury 500
Ford 460
Mercury 500
Ford 460
meltonhill
He runs the same as mine 14x10. You still have the sidedraft carbs on your motor? His has been changed to a 2 barrel at some point.
Mine was converted to 2 barrel also. I do have the side draft manifolds/carbs though.
Mercury 500
Ford 460
Mercury 500
Ford 460
