1984 360 sending unit
Posted: Wed Jan 20, 2016 2:08 pm
by shade2u2
There is a temp sending unit in the starboard manifold elbow that is suppose to connect to wire going to electronics control black box at the aft end of the engine. Well the male connector on the sending unit broke off.
Any ideas where to get a new one?
What does it do?
Thanx for any help.
Re: 1984 360 sending unit
Posted: Wed Jan 20, 2016 4:28 pm
by balthaus
Try looking around this website
http://www.hurrikain.com/ChryslerMarineStore.htm
I have purchased a couple of volt regs from them and will definitely purchase from them in the future. Mom and pop shop.
Posted: Wed Jan 20, 2016 9:07 pm
by barefoot99
It is for the exhaust over temperature alarm, oil pressure and temp sender all tye together Check Fast Jeff's info on this site. I forget the rating someone on here will know. I believe NAPA has them, you just need the correct temperature range. I'll look at the one on my spare engines to see if it has a number. Any marine mechanic should know. Post a pic on the FB page. All my manuals are on the boat, I think the engine manual lists the part number. Boat is 235 miles away and the memory fades as we age !
Posted: Thu Jan 21, 2016 6:08 am
You might have to convert the connector to something automotive. I used temp switches from 1985 (about) Pontiacs. Check the thread size as well to get one that fits.
Posted: Thu Jan 21, 2016 8:48 am
by shade2u2
Thank you all for the help.
The unit has 200F on it along with 363-D (part#?).
Here it is...
Posted: Thu Jan 21, 2016 8:57 am
by shade2u2
balthaus wrote:Try looking around this website
I really appriciate the link neighbor. :)
Are you at the Marietta Boat Club?
Posted: Thu Jan 21, 2016 11:44 am
by shade2u2
Think I found it... if this is a trip set switch and not a sending unit.
Sierra TS25111 or Stewart Warner 83307.
Posted: Thu Jan 21, 2016 1:56 pm
by balthaus
I am down river in Louisville KY
Posted: Fri Jan 22, 2016 8:33 pm
Note to all on temperature switches: I went through a bunch of 'new' ones a few years ago before I found one that worked (using a pot of boiling water and a meter).
