Rocker Switches
Rocker Switches
Any one know of a source for late Model 89-92 Dash Rocker Switches with internal indicator lamps that change color between Upper and Lower Helm use ?
New Endeavor
1991 41ft Aft Cabin
Louisville,Ohio River
1991 41ft Aft Cabin
Re: Rocker Switches
newendeavor
Do you have a picture?
Is it just a DPDT rocker with an led for each position or is there text that is lit at each position?
1984 32' Sedan FB
Twin Chrysler 360's
1.52:1 Velvet Drives
Ohio River
Twin Chrysler 360's
Ohio River
Re: Rocker Switches
There are DPDT,SPST, Momentary, etc. The ones in question are red in one position and green in the other. (Anchor and Running Light Status) If they were LED I would not have this problem !
New Endeavor
1991 41ft Aft Cabin
1991 41ft Aft Cabin
Re: Rocker Switches
newendeavor,
Man, that is a tough little switch to find.
All of the usual suspects, Mouser, DigiKey etc... don't seem to have it, as I am sure you discovered as well.
I did not notice an IP rating but the drawing does indicate a rubber gasket.
http://spec_sheets.e-switch.com/specs/C700019.pdf
1984 32' Sedan FB
Twin Chrysler 360's
Ohio River
Twin Chrysler 360's
Ohio River
Re: Rocker Switches
Big 's Rule !!!
Big 's Rule !!!
