Rocker Switches
Posted: Mon Apr 18, 2016 12:48 pm
by newendeavor
Any one know of a source for late Model 89-92 Dash Rocker Switches with internal indicator lamps that change color between Upper and Lower Helm use ?
Re: Rocker Switches
Posted: Mon Apr 18, 2016 6:24 pm
by balthaus
newendeavor
Do you have a picture?
Is it just a DPDT rocker with an led for each position or is there text that is lit at each position?
Re: Rocker Switches
Posted: Tue Apr 19, 2016 3:35 pm
by newendeavor
There are DPDT,SPST, Momentary, etc. The ones in question are red in one position and green in the other. (Anchor and Running Light Status) If they were LED I would not have this problem !
Re: Rocker Switches
Posted: Wed Apr 20, 2016 8:10 am
by balthaus
newendeavor,
Man, that is a tough little switch to find.
All of the usual suspects, Mouser, DigiKey etc... don't seem to have it, as I am sure you discovered as well.
I did not notice an IP rating but the drawing does indicate a rubber gasket.
http://spec_sheets.e-switch.com/specs/C700019.pdf
Re: Rocker Switches
Posted: Sat Apr 23, 2016 6:41 am
by MetalHead
