Does anyone know if the cam can be reversed on a Sherwood D60 pump? I put one together for a friend he put it in and it would not pull water. He put the pump in with the drain holes down (Same as I would have) and after taking it a part 2 times we then just turned it over and yep worked great. So Im guessing they have another part number for the cam or it can be turned to make the outer housing be correct.
D60 sherwood water pump cam
Jeff Monday (Blue Mondays)
Lower River rd
Rabbit Hash KY
Lower River rd
Rabbit Hash KY
Re: D60 sherwood water pump cam
As I recall, the new Sherwood G7 I bought for Mr. Starboard had the impeller set up for Mr. Port. I flipped the impeller over and all was well.
Hope that helps.
Hope that helps.
