solenoid
Posted: Tue Oct 11, 2016 7:05 am
by ddependo
Old wise Marinette men, Is there a "marine" solenoid or same as automotive?
Re: solenoid
Posted: Tue Oct 11, 2016 2:17 pm
by ericinga
I've compared the two versions and couldn't find a difference. I use the automotive version.
Re: solenoid
Posted: Tue Oct 11, 2016 9:12 pm
by Wilfred
Same part number as what was on boat and what is spec for a 1970 Ford
Got mine at NAPA
Re: solenoid
Posted: Wed Oct 12, 2016 7:48 am
by barkleydave
The question is: Is it marked "Ignition Protected"? If UL approved it will be marked. If no,t you could be making a dangerous assumption. Also the one that is "Marine" will have better corrosion protection (copper, nickel etc) on the terminals for the marine environment.
SAE J1171 approval
Re: solenoid
Posted: Wed Oct 12, 2016 10:54 pm
by Wilfred
A Sierra Marine 58-1841 part number, seems to fit LM318, widely available
I needed one quickly so I got one @ NAPA
Yes, use of non-Marine grade electrical engine components..DANGEROUS
Re: solenoid
Posted: Sat Oct 15, 2016 5:46 am
There's two varieties of these things: Those meant for starting the engine, and those that are a remote switch (left on) for paralleling the batteries. The latter is 'soft' energizing and can be left on without damage.
Re: solenoid
Posted: Sun Oct 23, 2016 8:49 am
by spdracer
The automotive solenoids do not have a long enough bracket to use both mounting bolts. Other than that they work just fine and are safe to use.
Re: solenoid
Posted: Mon Oct 24, 2016 3:28 pm
by Leviathon
Hey Fastjeff,
Question on those other solenoids with battery cables running to them. That is the first time I have seen that on my "new to me" marinette. Necessary? Still do not completely understand the purpose and have seen the set up without.
Re: solenoid
Posted: Mon Oct 24, 2016 7:41 pm
by bill
Steve,
On my 1975 37 Marinette with two batteries and one of those batteries runs all the 12 volt stuff. Some times the house battery drains down one battery and the engine wont turn over.
There is a parallel switch on the lower helm, it looks like a silver horn push button.
This actuates the parallel solenoid switch in the engine compartment.
Just like jumping a dead car battery but with press of a button instead of jumper cables
Re: solenoid
Posted: Mon Oct 24, 2016 8:58 pm
by Leviathon
Alright - will search for the silver button to see if I have the same - thanks Bill.
S
