Flying Bridge Restoration
Studini
Re: Flying Bridge Restoration
Postby Studini » Sun Nov 04, 2018 8:14 pm
carl wrote:Picked up my new Fly Bridge switch panel and the circuit breakers arrived from http://www.onlinecomponents.com, this is the last of my switch panel/circuit breaker upgrades. More to come on the Fly Bridge restoration...
Hi Carl,
I know this post is a bit dated but can I ask where you got your panel made? It looks great!
88 32’ Fisherman
“Get Busy Livin”
Twin 360’s
Fairport Harbor, Ohio
Studini
Postby Studini » Sun Nov 04, 2018 8:15 pm
88 32’ Fisherman
“Get Busy Livin”
Twin 360’s
Postby shade2u2 » Mon Nov 05, 2018 9:24 am
Carl,
Also - is your new panel backlit to display the lettering at night?
carl
Postby carl » Thu Nov 08, 2018 5:36 am
I put together a drawing detailing the layout then I had a local sign shop help me layout and laser cut all of my new panels. I told them what I wanted where on the panel and they had them to me in just a few days. Bring your panels in to a local shop near you and start the conversation with them, hopefully they can fabricate them for you. I backlight my panels with a LED strip light, they come in a variety of lengths, mine are 6" long. Using a LED strip light eliminates all of those incandescent bulbs the factory installed.
Twin Crusader 350's
Chickamauga Lake, Tennessee
carl
Postby carl » Thu Nov 08, 2018 9:49 am
Sanded, primed with three sprayed coats of "Interlux Brightside Steel Grey".
Twin Crusader 350's
carl
Postby carl » Mon Nov 19, 2018 5:25 pm
She is coming together slowly but surely...
Twin Crusader 350's
ddependo
Postby ddependo » Tue Nov 20, 2018 7:09 am
Looks good Carl.
carl
Postby carl » Sat Nov 24, 2018 12:49 pm
Starting to fit out the bridge. Steam cleaned and coated the underside with white Interlux BilgeKote paint, it looks better then the bare aluminum and will be easier to keep clean but I did it primarily so that when I need to open the cavity to access the wiring and components under there it will be brighter and easier to work in with a flashlight. New gauge dash panels installed, new horn button, Bennett trim tab switch panel, auxiliary dual USB outlet port and new ignition fuse holders. I did away with the original toggle switch ignition and installed keyed ignition switches.
Twin Crusader 350's
Postby Fastjeff » Sat Nov 24, 2018 5:51 pm
Lookin' good!
carl
Postby carl » Sat Nov 24, 2018 7:37 pm
Horn, AM/FM Antenna, Handrails (2), Anchor Light and VHF Marine Radio Antenna Mounts (2) installed today. Additionally you will see four stainless bow eyes, one in each corner of the fly bridge, these are permanent and in place to rig the bridge onto and off the boat. Underneath the bases of the handrail standoffs you will see my Starboard insulators installed to separate the dissimilar metals stainless and aluminum.
Twin Crusader 350's
