water pump - another question
steveintn
#1 Posted : Thursday, July 02, 2009 10:08:15 AM(UTC)
steveintn
recently when i turn on my water pump. it does not want to stop running and making clicking sound. I assume i must have a leak somewhere and it can not build up preasure.
any suggestions on where to start looking for the problem?
89 28 express
- steve
steveintn
1989
28ft Express
w - Twin 318's
#2 Posted : Thursday, July 02, 2009 11:14:04 AM(UTC)
It will do that if out of water.
rockit
#3 Posted : Thursday, July 02, 2009 2:13:19 PM(UTC)
rockit
Steve:
Check your water heater. When winterizing, you disconnect the hoses from the heater but connect them together to run the antifreeze through the lines. You also open the heater drain valve. If you do not get the hoses back on correctly and remember to close the drain valve, the transfer pump will run constantly. It will transfer water from the main tank to the water heater in the engine compartment and fill your bilge. It should now be obvious why I know this. . .
If that isn't the problem, check you connections at the tanks and at the faucets. On my 28' express there is a junction just forward of the port engine and another underneath the aft companionway hatch.
Good luck!
Joe
Joe
1977 28' Express
Twin 318s, raw water cooled
Ohio River
steveintn
#4 Posted : Friday, July 03, 2009 3:46:58 AM(UTC)
steveintn
thanks
ends up my pump is leaking. I have an odd looking pump jabsco 36950-1000 it uses a small fan belt. I will search the web to decide if it can be rebuilt or replace with a self contained unit.
steveintn
1989
28ft Express
w - Twin 318's
#5 Posted : Friday, July 03, 2009 4:17:27 AM(UTC)
Jabsco probably makes a repair kit for that unit. For what it's worth, I ditched my fan-drive belt years ago. Belt kept slipping off and was a royal pain to get at it for adjustment. So, I went with the self-contained drive type. No more crawling into the "wine cellar". Also, it cycles less when cold water is drawn.
#6 Posted : Saturday, July 04, 2009 1:56:52 AM(UTC)
Pump housing is probably cracked and impeller is bad.. belt slipage etc.
Will cost more to rebuild than to replace with a piston driven diaphram pump.
Will draw less amps and easier to service/replace.
I like the old belt drives on larger vessels with lots of water draw demands only when they are easy to get to to maintain.
#7 Posted : Saturday, July 04, 2009 4:11:59 AM(UTC)
Does it look like this?
If so you would be better off with one of these
you can also do away with pipe nipples and use threaded fittings to make winterizing much easier.
steveintn
#8 Posted : Saturday, July 04, 2009 11:20:16 PM(UTC)
steveintn
THANKS TO ALL for feedback.
yes, the photo is dead on to what i have. Great advice.
steve
steveintn
1989
28ft Express
w - Twin 318's
#9 Posted : Tuesday, July 07, 2009 5:46:19 AM(UTC)
Take Karl's advice and toss that old clunker out. I did and have never regretted it.
#10 Posted : Tuesday, July 07, 2009 6:39:45 AM(UTC)
I fitted one of the new pumps to my boat. It says that it will run dry, but if it does so for long the brushes will be used up. This happened to me when I inadvertently left the water system on while away from the boat for a while. The pump itself was OK, but the motor brushes were just dust. I had to remachine the commutator and cut brushes to fit (I am too cheap to pay their prices for rectangles of graphite, take that FJ!). I have fixed the problem by adding the water switch to my shutdown list. Eventually, I will fit a pressure sensor that shuts down the pump if water pressure is lost.
This page was generated in 0.119 seconds.
