I discharge the shower sump, which has its own little thru-hull, through the same thru-hull as the forward bilge pump.
The hose from the forward bilge pump rises straight up as high as possible, and then slopes down at an angle to the thru-hull. This minimizes the amount of "flow-back" when the pump turns off, keeps the hose empty, and should make it a little harder for water to come in from the thru-hull.
Just at the thru-hull, there is a "T" and the smaller hose from the shower sump is connected. This hose rises straight up from the shower sump, and then angles down to the thru-hull. Just to be on the safe side, I have a one-way valve just above the shower sump pump to keep the bilge pump output from coming back into the shower sump.
It all seems to work OK.
