On question on the paint job.
I did a lot of the work myself but I had help and a shop (inside on the weekends) to work in.
I sand blasted it to bare metal.
The paint I used is Interlux Prefection. (per there insturctions)
I had to washed bare metal with eching wash. (I added this step becouse the boat sat a few days before I could get the primer on.)
Primed with Vinylux prime.
Interlux epoxy primer.(I did not have the correct nozzle and it cost me!!! I had to sand the whole boat becouse of the the rough finish it left.)
Coated with prefection
I had 2 experenced people spray. If i did, there would not look good.
Note: You have to use a fresh are hood to spray Prefection.
You can roll prefection, the paint is formulated to roll. but do not try it on a hot day a freind tried on a 90 sunny day and it did not lay out.
You may be able to put prefection over origional paint. I forgot to sanblast the cover pannel and cabnet doors on the flybridge, I scuffed and painted over old paint. It did not lift the old paint.
Below the waterline I rolled on Interprotect 2000 with Trilux 33.
