I will re-check the connections. Interestingly, one unit works now and it's on the side with multiple extra connections to feed the generator. It's the simple "straight through" side that is messed up. I'm on my third set of flow transponders (if that's the correct name) with the patient help of the mfr (Navman).
My backup strategy will be to assume both engines are running at the same approx fuel consumption rate and multiple by 2. I can verify that at the fuel dock. But that, of course, isn't why I invested in a 2 unit system.
