Parkuet flooring in cabin
28fisherman
#1 Posted : Tuesday, August 11, 2009 8:43:47 AM(UTC)
28fisherman
I have been searching for two years now for some type of flooring for my boat and think I may have found something.
What I am looking at is a maple parkuet that is 9x9 and made out of strips of wood 1 inch wide.
Anyone have any thoughts or suggestions on this?
NightMoves
#2 Posted : Tuesday, August 11, 2009 10:11:52 AM(UTC)
NightMoves
I would love to have wood but I spend too much time taking the floor up for different projects and the carpet just rools up and I can get to the plywood
Mike
#3 Posted : Tuesday, August 11, 2009 10:27:45 AM(UTC)
How shall I put this. OK- Maple home center parquet flooring is cr*p and does not belong on a boat. My project 28' had it glued down all over the cabin. It kept shedding the little one inch squares. The access hatches for the shower and forward bilges were all covered up. It added a lot of weight to the engine hatches to a dangerous level. Pulling it up was a nightmare. I had to take a day off from the fumes from the adhesive remover. When I finished I had to level out the decking with wood filler. If I knew what a big rotten job taking that cr*p up I would never bought the boat. Just forget about it. Make some good patterns for cutting out carpet. Change it out every couple of years.
#4 Posted : Tuesday, August 11, 2009 10:28:11 AM(UTC)
I seem to recall someone else who did that. The wood sections moved all over the place with expansion/ contraction and left gaps, loose tiles and rough edges.
We went with a linoleum product that looks like wood (thousands of variations available) and has held up perfectly for 4 years now.
28fisherman
#5 Posted : Tuesday, August 11, 2009 11:25:54 AM(UTC)
28fisherman
To address the responces, the flooring is not home center stuff. It is strips of 1 inch wide by 1/2 inch thick by 9 inch long maple held together on the back with wire to create a 9 inch square tile. I think the expansion and contraction may be minimal due to the small size of the strips.
For installation I thought I would remove the old floor plywood and use it as a pattern to cut two new pieces that would be stapled together with a layer of ice and water sheild in between. I would attach the flooring to the subfloor and then sand and finish it all in my garage. The max length is 9 feet and max width is 3 feet and there are two access hatches in the floor so it shouldn't be to heavy to drop it in place in the boat. I thought I would install some kind of baseboard to hold down the perimeter and try to screw the perimeter of the hatches to the framework from below. If it fails I can remove and try something else.
With this additional information what are everyones thoughts?
Thanks, Jason
#6 Posted : Tuesday, August 11, 2009 12:20:38 PM(UTC)
Parquet flooring looks really nice and classy. That established, it also scratches fairly easily and you'll be tempted to sand it a lot which would be a mistake because wood is supposed to wear and get some character and scratch coverup would be better. For my money, carpet is the way to go. With all the time you'll save not having to install wood, you can....make your own fishing lures.
MaxII
#7 Posted : Tuesday, August 11, 2009 4:12:56 PM(UTC)
I installed the parquet flooring about 3 years ago and have had no problems except when my AC spits out water and stains the wood. I installed a carpet throw below the AC outlet and clean my AC more often and end of problem. Carpet on the boat as it was for first year just felt and looked dirty and sticky. When I installed the wood parquet, it was much easier to clean and looked better. I cut out for the hatches and they are easy to remove. We have a 50lb dog that lives with us on the boat Friday through Sunday evening and there are no visible scratches (a lot of dog hair that becomes very visible on the wood surface but no scratches). Cost is good and performance is great. Cleanup is easy.
A friend installed wood plank flooring in his 32 and coated with polyurathane and it looks great. First year for this installation but we will continue to monitor and comment as the subject arises from time to time.
It may come down to personal preference. Cost to replace with either wood or carpet is not major and can be changed from time to time.
Max
#8 Posted : Saturday, August 22, 2009 9:26:05 AM(UTC)
You can make a suitable replacement for the factory plywood floors from tongue-and-groove wood of sufficient thickness (depends on the strength of the wood) pretty easily.
I used aluminum angle underneath to hold the boards togther, screwing up from below. I put some pictures on the forum a while ago, maybe they are still here. If not, I will repost.
#9 Posted : Sunday, August 23, 2009 2:36:13 AM(UTC)
I still had the original parquet floor but it was so dirty and black etc. Was going to replace it but I took the belt sander to it and she cleaned up real nice.
Luckily the floor comes completely out so working on it was much easier. The pic below is after sand and multiple coats of urethane. Really surprised how well it turned out.
GB49 attached the following image(s):
GB49 attached the following image(s): parquet.JPG
jhemp3
#10 Posted : Sunday, August 23, 2009 5:48:27 AM(UTC)
jhemp3
Good looking floor, Karl.
Jim Hemphill
Detour
This page was generated in 0.578 seconds.
