Using 1/8 inch will not make the floor stiff enough without adding a whole bunch of cross beams.
You might consider this approach instead: Lay down 1/2 inch pressure treated plywood first and screw it in place with countersunk screws from ABOVE (the easy way). Then screw the aluminum down to it, also with countersunk screws from above.
You don't need to be fussy laying down the plywood, which simplifies things, but be sure that the wood and aluminum seems aren't near each other. I made the longitudinal aluminum seam go through the hatch opening, where the plywood seam was where it came from the factory.
I also made the cockpit hatch from aluminum, doubled it up with another sheet inside the hatch opening. Even still, it's bit too flexible.
PS: Got some photos of the finished deck if you're interested.
