This is how we did it using pink RV anitfreeze with rust inhibitors.
1 - Push one end of 3/4" heater hose into strainer housing top inlet with water hose on other end (
see pictures)
2 - Start engine and let run to get oil warm
3 - Change oil and filter (Fram PH16, 1 qt of Lucas Heavy Duty Oil Stabilizer, 1 gal Shell Rotella T 15W-40) and then restart to make sure oil pressure is OK
4 - Remove the brass water drain plugs from both sides and let drain
5 - Remove thermostat housing and t'stat
6 - Pour pink AF into t'stat opening until pink comes out plug holes
7 - Replace plugs and top off with AF (it took 1.75 gal)
8 - Replace t'stat housing and snug bolts (leave t'stat out)
9 - Put AF in bucket, remove water hose and run engine until pink comes out exaust (sucked up 3.25 gal)
10 - Remove pump and impeller
We keep her in a
insulated quonset hut that rarely gets below 20 degrees. Last year it never got below 25.
Specs:
